Drake Tank
vman
Massachusetts
Had one of my handy men put in a drake in a unit. Is the tank suppose to wobble alittle or not? Or is it suppose to stiff/steady as a one piece?
Any ideas?
People are often leary about tightening up the tank. A little movement is okay, but you can get it almost tight to the bowl if you do it slowly and evenly. You don't really want tight porcelain to porcelain, almost touching.
Only 1 response? So are we saying it is ok if it flexes back a bit. It doesn't seem to flex forward at all.
As jadnashua said, some people are really unsure on how tight the porcelain should be. I personally like to couple them as close as I can so they don't wobble. If your scared of tightening any more, put a plastic wegde where it won't be seen to stop it from moving.
