PIZ
- Messages
- 13
- Reaction score
- 0
- Points
- 0
We bought a home (built in the 50s) last year. There is a bathroom downstairs that is built up from the floor. The shower in it has never been used since we moved in and we had boxes of moving things piled in there. We finally had some time to get to the boxes and I noticed there was quite a bit of water at the bottom of the shower and I pulled off the drain screen and there was water in the drain. How could there be water in there if I never use it? I flushed the toilet, which is about 10 feet from the shower to see if water came through the shower drain and it did not. Upstairs, when I do the dishes, when the water drains, I hear a gurgling, so maybe the problem is a venting problem.
Also, on the bottom (where the wall meets the floor) of the built up floor on the side of our basement floor there is some water, and I'm not sure if this would be caused by hydrostatic pressure or a leak in the plumbing of the built up bathroom.
Also, concerning the bathroom in the basement. The floor is concrete, and there is a shower, sink, and toilet in there. Would the floor be solid concrete? Why I'm asking is, if the water on the basement floor is from hydrostatic pressure, how would I stop it, since the place where I'd put the hydraulic cement would be about 5 feet from the home's outside wall?
I hope this wasn't too confusing, and I'd appreciate any advice you could give. Thanks in advance.
