statjunk
02-07-2008, 05:18 AM
Hey guys,
I feel like my issue should be real easy.
I have a shower that has a newly installed Moen 3330 valve. After I installed it a few months ago I tested it and water came out of both shower heads. I recently tiled the shower and put the escuchean on last night. Nothing came out. I took the escuchion off and thought that I must have closed the little stop valves. Turned the valves one way and tested withough handles. Simply by pulling the lower handle stem out. Nothing. Turned the screws the other way and again nothing. Pulled the lower stem out and turned the top diverter handled a complete 360 degrees. Once again nothing.
There is definetly water coming to the room because I have a jacuzzi tub in the room and it has water. The piping for the shower branches off the same 3/4" line that runs to the jacuzzi. Also there are no other valves in the walls.
I stuck my hand into the hole with the valve and felt the lines in the walls. They weren't cold as if frozen. Also the valve is in an interior wall not an exterior wall. The lines for the jacuzzi run on an exterior wall so those would be most likely to freeze.
I feel like the answer to this one is going to be real simple. Any ideas?
Tom
Tom
