Zenman
04-02-2005, 12:52 PM
I have a second story bath. The toilet will be flat vented, the wye is rolled up 45 degrees then straight back to the closest wall (1/4 inch per foot slope towards the drain). Once the vent goes vertical should I put in a cleanout? Under UPC I read that cleanouts are not required above the first floor, but thought it might be a good idea. The cleanout would be in a closet. My plan was to put it 6 inches above the flood rim of the toilet. But I have two questions...
1. Should I put in a cleanout? (or is this overkill)
2. What type of fitting to use? (A "wye" or a "sanitary T" or doesn't it matter)
Thanks for any info...
