Fudog
- Messages
- 28
- Reaction score
- 0
- Points
- 0
I have a ceiling fan with one light in the center. The light socket is a porcelain type and needs replaced as the light flickers and I can hear a little arcing sound. I shut the power off and made sure all of the connections were tight,made sure the socket itself was tight as it was loose,also pulled the piece in the socket where the tip of the bulb touches for a good contact.Put the bulb back in and still a little flicker,removed the bulb and upon closer inspection I could see where there had been a little arcing.The ceiling fan is fine I just need to know where I can buy the porcelain type socket to replace it. I took the bulb out until I can install a new socket.Your suggestions will be appreciated on where to find this.THANKS
