View Full Version : Bathtub overflow drain
npickus
02-02-2008, 05:31 PM
Water comes in faster than my overflow drain can get rid of the water. Is this common or is it indicative of a problem with the drain?
Dunbar Plumbing
02-02-2008, 06:16 PM
Common on all tubs
jadnashua
02-03-2008, 03:02 PM
Humm, a drain line is probably 1.5", and the supply is probably 1/2" (although under pressure). I'd expect a drain line to be able to handle most supply situations without backing up. While not using the overflow to drain, my tub drains about in half the time it takes to fill up. The overflow goes to the same place as the main drain. Anybody else?
