View Full Version : Universal connection
hilliap
02-02-2008, 12:28 PM
Hi...I'm stuck! I decided to put in a new shower valve, and my buddy gave me a deal on a Grohesafe EF valve (35.253.00) with 'universal connection' for the hot/cold inlets....
OK, I'm fairly new at this....what is a universal connection?? The inlets have 1/2" male threads...but not sure what female connector to get.
Any help would be appreciated!
jadnashua
02-02-2008, 02:48 PM
Try a piece of 1/2" pipe and see if it will fit inside the opening. Many are made so you can solder a pipe to it directly, or use the threaded fitting. If you solder it, remove the cartridge first so the heat doesn't damage it. Same procedure is needed - clean and flux, then heat the fitting (in this case the valve body), not the pipe. Because of the mass, it will take awhile to get it hot - this is where a MAPP gas torch can help, but is not essential, just faster.
hilliap
02-11-2008, 11:04 AM
Thanks...that worked!
