low flow toilet with size restrictions
Knabe
i am looking for a comfort height toilet that is higher than 14 inches at the bowl, can accept a 5 3/4" high water hookup out of the wall, a 26 rather than 28 inch length from wall, i guess this is a round versus elongated bowl one piece toilet that is a low water user, something on the order of 1.28 or lower.
toto has an american disability model that is 1.28gpf, but it is an elongated bowl versus round bowl.
is there a reason the comfort heights only come in elongated bowls design?
also looked at kohlers , but haven't found one yet, although they do have 1.1 gpf models
i have a leach line and would like to significantly lower my water use from toilets, and replace my 25 year old toilets which must be flushed 2-3 times.
hi terry, found that one as well.
toto doesn't have a model that is like that in the comfort height, which i guess is either at ADA level, or some other height with the round bowl.
i think the 1.1's are available with basically the same dimensions.
i'll double check, but i'm pretty sure our current toilet is 14" off the ground (bowl height). i've tried a few of the higher seats in demo stores but can't remember what height they were other than they were higher than the low ones which i guess is around 14-14.5"
mark
