View Full Version : spray foam insulation on pex?
remodelbob
01-27-2008, 11:10 PM
what type of insulation do you use around pex when going between stories? normally i would use spray foam around the copper and romex, but I am not sure if that will hurt the pex.
patrick88
01-28-2008, 07:28 PM
Why would you use spray foam? You ever think what a pain it will be to make any repairs in the future. If the pipe chase is in the middle of the house I would not bother to put anything on it. I would only put pipe wrap on any pipes. I think it is alot simpler to use and looks alot nicer.
remodelbob
01-28-2008, 07:50 PM
i need to get something in there as a fire block. spray foam is fast and easy.
patrick88
01-28-2008, 08:13 PM
Oh cool I see your point.
Redwood
01-28-2008, 10:11 PM
Spray foam is rated as a fire stop/block material?
frenchie
01-29-2008, 12:46 AM
Some of them are.
fidodie
01-29-2008, 04:55 AM
I've gotten the spray stuff onto vinyl replacement windows, and it definately compromises the finish. The windows should be tougher, since they need to stand up to UV.
Rock Wool would allow you to fill the whole (hole?) space. Especially important in exterior of balloon framed homes.....
got_nailed
01-29-2008, 05:44 AM
I cover about 1’ of the pipe in duck tape then I use spray foam. I have used Rook Wool but the inspectors don’t like it where I’m at.
remodelbob
01-29-2008, 10:01 AM
I was thinking about tape, but I also worry about that compromising the PEX. PEX sure is delicate...
How about foam pipe wrap and then spray foam around that?
patrick88
01-29-2008, 02:19 PM
I would do that that. If I had to do what you are talking about I would do that.
