View Full Version : low hot water pressure
Low hotwater pressure once in a while . How come?
Redwood
01-27-2008, 04:54 PM
How do you heat your hot water?
patrick88
01-27-2008, 07:01 PM
I think giving more info would be a good idea. Is it just in one place?
hot water tank is gas. low water pressure is at any tap in the house (hot water only) it is not a constant loss of pressure only once in a while . cold water pressure seems constant. my PRV ( pressure relief valve) is opening regularely .
nap
patrick88
01-27-2008, 08:22 PM
nap
I assume you meant the valve on the top or side of the water heater. If so it is a T&P (Temp. and pressure relief valve) and if is popping open you might have high water pressure and have need for a x-troll tank installed.
Redwood
01-27-2008, 10:04 PM
We need 2 measurements to be taken. We need the hot water temperature measured with a thermometer, and we need you to get a pressure gauge that screws onto a hose bibb and take a pressure reading.
