View Full Version : tub to toilet dimension
7echo
01-27-2008, 03:09 PM
I have about 11" from the edge of the bowl to the edge of the tub. As part of a remodel I want a wider and deeper tub. The tub we like will end up about 6" from the bowl.
Too close? If so, why?
Thanks
frenchie
01-27-2008, 03:22 PM
Side, or front?
Code says you need 24" clear space in front of the toilet.
18" from centerline, on either side.
7echo
01-27-2008, 04:12 PM
Thanks for numbers.
I am talking about the side clearance. My current set up is already invading the 18" dimension. Might have to cheat the clearance a little more.
frenchie
01-27-2008, 05:20 PM
The 18" is from centerline - not the edge of the bowl. IE, the toilet centered in a 36" wide space.
It is 15" from the centerline and yours should be okay when you finish.
frenchie
01-28-2008, 12:21 PM
...sent me to the code book.
HJ is right. It's 15" from the centerline, 21" in front.
