View Full Version : 3 handle shower head configuation woes
Calyx
03-31-2005, 11:24 AM
We are trying to remodel a bathroom in a house built in 1930. There is currently a 3 handle faucet in the tub for the tap/shower. (the 3 handles connect to one horizontal pipe that then connects to the rest of the plumbing behind the tub wall).
It appears that the "spread" is 12 inches for this set up. I can only find 3 handle arrangements with an 8 inch spread.
Any ideas who might make a 3 handle faucet that are spaced farther apart? We won't have any spare bathtub tiles and don't want to re-tile the bathtub. I can't seem to find a remodeling plate that would be wide enough to cover the 2 outside holes and allow us to install a single handle faucet.
Help.
Thanks
Calyx
master plumber mark
03-31-2005, 06:52 PM
all you got to do is buy a normal delta faucet with the standard 8 inch spread.
the delta facuet brass arms can be cut between the two sections and extended outwards with just normal 1/2 copper couplings to the size you wish to make it.
Yes thats right, they are made that way to the exact size of 1/2 copper so
they can be extended with copper pipe and couplings. Aint it wonderful!!
It just requires a tubing cutter and the ability to solder properly the copper extensions in between two or three faucet bodies.
If its a three handle faucet you are replaceing for either a tub or shower,
I suggest that you use a two handle faucet and put a Delta faucet Deco plug over the center hole. And use a pull down diverter spout that also comes from Delta.
Also take the plastic parts out before you solder this little thing up so you dont overheat the parts.
good luck and have fun fun fun
this has gotten me out of many jams with old funky faucets.
Clayton
03-31-2005, 08:08 PM
Here is a previous thread about the same topic that includes my post with the Delta faucets as Mark was mentioning.
http://terrylove.com/forums/showthread.php?t=1693
03-31-2005, 09:07 PM
It is probably 11" centers and several companies, such as California Brass make 11" three valve faucets.
