View Full Version : Rough-in Layout
Cgbuffalo
01-25-2008, 12:25 PM
I am new to the world of major plumbing, so please be gentle. I've looked all through this site and others to find a set up similar to that in my basement, but have had no luck. Can anyone help me out with labeling the pipes that I can see? My initial assessment was that there is a toilet drain (black cover), sewer trap (left, level with slab), and a shower drain (on right). Is the 2" pipe (located only 4" behind the black cover) a sink drain or a toilet vent?? I'd rather not combine the toilet tank and the sink (my friends might not think that's too sanitary). Am I going to have to move the 2" pipe, or can it be angled into the wall somehow? Thanks for any help in advance!
Mikey
01-27-2008, 06:16 PM
I'm going to guess that the thing on the left is a cleanout. You might be able to take out the plug and peek inside to see where things go. The 3" pipe on the right is a mystery -- why 3"? Aren't the as-built plans on file at your local building office? If not, it might be time to call a pro, maybe with a camera.
fidodie
01-28-2008, 06:18 AM
pull the cap off the one to the right - if there is no trap, it may be set up for the toilet (although attaching a flange will be a fun job), the 2" sticking up is the sink/vent, the one flush with the floor is a check valve/clean out, and the black one is a clean out. I don't think there were plans for a shower.
the check valve and clean out would be concealed (not covered, just concealed) by a vanity.
if there is a trap on the right, then it was meant for a shower, and i'm way off.
Is the floor poured up to the pipe without anything to provide some movement? (bad)
By the way, this is a guess - if it was done with inspections, there should be a plan on file with the city, and a letter that specifies it was only roughed-in.
if the black one is foam, then it was meant for a closet flange. And i have no idea what they were thinking!
Cgbuffalo
01-29-2008, 07:49 PM
Pat, you saved the day. After calling the city and getting shut down, I called the builder. He was no help, either. I saw your post and it provoked me to rethink the bathroom layout. The 3" is for the toilet, the rest on the left is for the sink. There is a drain to the right of the toilet stub, but it was WELL hidden under the concrete. This was no veneer of concrete... It all makes perfect sense, now. I slept well last night! haha
Thanks for your help!
fidodie
01-30-2008, 02:55 AM
You are welcome.
