sinner2943
- Messages
- 1
- Reaction score
- 0
- Points
- 0
I need help. In Jan 2005, we installed a new pump motor, pressure switch, pressure tank and compacitor/relay box. Before we replaced these items and now, we are consistently replacing pressure switches. The switch starts clicking on and off continously, until the pump starts. But after a while the pressure switch wears out, or so we are told. Anyhow, we thought we fixed this issue when we installed all new equipment. But it is happening again. On this past Saturday, I went out and started all of my farm chores, including pumping large stock tanks of water, everything was working great, I finished chores, proceeded to the house, and there was no water! I went into the barn looked everything over, still nothing, I tapped on the pressure switch and boom, everything worked. The water system than worked for several more hours, than it went out again, so I went back to the barn tried tapping on the pressure switch, this time nothing. So I figured here we go again, I went the the hardware store, bought the same kind of pressure switch and went home to install. I installed the new pressure switch and we had water again. Than comes Sunday, started out again the same way, did chores everything was fine, great water pressure, I thought I had it fixed, wrong! Went into the house couple hours later no water again. I gave up at this point and shut the power off. Today is Monday, I decided to call for advice, the plumber told me to check the pressure in the pressure tank, it was at 30psi, he said with a 20-40 switch it needs to be at 18psi. So I let air out of the tank, I than reconnected everything, turned the power on, and heard the pump kick in but no water, just air, the pressure tank no had 50psi???? I thought it is to stay at 18psi, correct? I than found a small area were the pipe had froze up, I thawed this and guess what we had water. The well would run for a little while shut off but than will not start up again. Its like the pressure switch does not tell it that it needs to kick back in. Please help I am so done with this ......
