electromechanical
- Messages
- 2
- Reaction score
- 0
- Points
- 0
What would be a good reason to put in a 3 wire vs a 2 wire submersible pump?
I recently bought the house and there's a fairly new shallow well jet pump and bladder tank now, in the basement. When it turns on the noise is enough to wake the dead, and besides I think the foot valve is leaking. The well is about 60 ft. deep with a 6" well casing about 10 feet in front of the house. It has a welded 6" cross connector pipe below frostline to the house. I'm strapped for cash, and my electrician brother and I could replace the pump and piping, with local permit.
Since the current system has old galvanized pump and suction piping which I wouldn't use again, what recommendations would anybody have re new piping? Polybutylene (its got to be a pain to work with, correct?)? Is
1 1/4" PVC now used instead? What schedule? I'd rather not dig 5 ft. down to the cross connector, saw it off the vertical pipe, weld on a patch, and put in a pitless adaptor.
If using PVC, at the 90 degree junction (tee fitting) from the cross connector to the vertical pipe would PVC support the weight of the submersible pump and piping? Would the horizontal PVC cross pipe eventually chafe through at the load-bearing point?
For a 60 ft. well, how much horsepower is needed for 60 or more PSI at the tap?
Thanks much for any info.
