View Full Version : Swap Price Pfister 7105 Cartridge with other Fixture cartridge???
kwbollinger
01-18-2008, 02:23 PM
OK. I hope this makes sense. I have 2 showers and a tub that are all using a fixture that is marked as Price Pfizer 7105 on the valve casing. This unit has a knob that you pull out to start water flow and twist clockwise or counter clockwise to adjust water temp. The units are 12 years old and becoming harder to pull out and push back in! I figure I could replace the inner cartridge on all 3 and that would solve the problem ... but what I would really like to do is to replace the guts (cartridge) of the valve with another style cartridge that is not the pull out and twist knob type. Are there other cartridges that I could pull from a new fixture that would fit the 7105 valve case? ... I don't want to have to remove the 7105 unit & go through the hassle of the full install (open the wall, soldering in new pipe, etc.). Advice from the experts would be appreciated. :)
jimbo
01-18-2008, 03:51 PM
NO.. You can replace your parts with new ones, same part. PP doesn't make any valves with the pull-out cartridge any more. Parts are very unique and specific, not interchangeable
kwbollinger
01-18-2008, 10:30 PM
Thanks. I did some more checking and believe that the valve I have is the Series 09 and uses 974-292 cartridge. Now PP indicates that it was also available with a lever instead of a knob for use by someone with a handicap.
Does anyone know if after I replace the cartridge, rather than using the knob as the pull handle I could install a lever? Was there a difference between the knob version of the 09 Series faucet vs. the one that came with a lever? The lever would be easier for my mother-in-law to use.
Thanks.
The insides are the same, the handle is the only difference.
raff98
03-01-2008, 06:01 PM
I am remodeling my shower, and have the ability to replace the cartridge. It would be real pain to completely replace the faucet, so I am just trying to replace the guts.
I have unscrewed the chrome cap, but cannot get the black plastic cartridge out. (tried pulling, twisting) Any ideas? Also, any ideas where to get parts?
Thanks
Ralph
