View Full Version : wirsbo expander fittings or shark bite
remodelbob
01-17-2008, 10:25 AM
I am installing PEX (wirsbo) pipe and am undecided on what fittings to use. I have a plumber that said he would come do all my connections using the wirsbo expander tool or I can use shark bite fittings. i think it would probably cost less with shark bite, but they seem to get mixed reviews.
what would you guys do?
jadnashua
01-17-2008, 11:15 AM
Use the Wirsbo fittings...if you are going to do this yourself, see if you can rent the tool. Or, buy one then sell it. Otherwise, let the plumber do it all. Less chance of a problem. The sharkbites are a good product from what I've seen, but make sure to buy the end clean up tool. This puts a microbevel on the end and makes it easier to insert into the fitting without tearing up the O-ring.
01-17-2008, 11:17 AM
I would use the wirsbo fittings and expander.
master plumber mark
01-17-2008, 03:10 PM
Shark bites can save you a lot of greif
in emergencies but they are not too pretty
when you are trying to run manifolds the
expander fittings looks much better
http://onsmartpages.com/weilhammerplumbingco/nss-folder/pictures/si_UEw80h80_DSC06114.JPG (http://onsmartpages.com/weilhammerplumbingco/pictures/view_alone.nhtml?profile=pictures&UID=10225)
master plumber mark
01-19-2008, 06:30 PM
http://onsmartpages.com/weilhammerplumbingco/nss-folder/pictures/si_UEw80h80_DSC06191.JPG (http://onsmartpages.com/weilhammerplumbingco/pictures/view_alone.nhtml?profile=pictures&UID=10229)
copper to old poly buteline pipe.....
will have to come back in the spring and change outabout 90
feet of the stuff....
but for today with the temps at 5 degrees.....
this saved me a lot of troubles
dmaceld
01-19-2008, 07:08 PM
I think the tool and clamps come from Watts, but they are branded by Zurn and whoever else. Look to me like a pretty good way. Advantages of crimp with an easy to install format using stainless steel clamps. One tool does 3/8" to 1" pipe. Tool is about $80 for no name on internet, $95 locally unbranded from Taiwan, and $150 w/ Zurn name from a local supply house.
