Nate R
Ugly drawing attached. Black line is just a break in the drawing. It's not all inclusive. Assume 1/4"/foot slope for all horizontal runs. Vertical pipe in front of washer drain is the vent for it.
Looking for guidance on type of fittings mostly.
1. Where sink drain joins Tub drain line, what kind of fitting should I use? (San T, Wye, etc)
2. I'm assuming a normal Drain (Not vent) elbow is fine here?
3. Fitting type needed?
4. Can I vent like this, or does the vent need to come off of the trap arm before the vertical drop? What fitting is needed here?
First point: I have a 1.5" Washer standpipe now. My W/D is a stacked single unit only 24" wide, and we will only be making enough space in the kitchen between cabinets for a 27" wide unit. So the machine will always be a small unit, and thus not have huge amounts of water coming out. The 1.5" has been working fine for us even though the rest of the drain line currently is not ideal. (There is a low spot and a Fernco in the branch) And it IS legal in WI to have a 1 1/2" line on clothes washer.
So, with the correct fittings, what's wrong with this setup? Recommended cleanout locations? Thanks for your time and effort in advance!
