New Gas Water Heater
ddmoit
SE Tennessee
I'm in the market for a new gas water heater. From what I gathered from a search on this forum, I should be fine going with any of these brands:
Rheem
Ruud
Richmond
Bradford White
Additionally, I should avoid Whirlpool.
The good model is about the same as the best model.
I've seen Richmonds sold locally, so that is likely what I would get.
Please correct me if I have the above information wrong.:eek:
Is there any advantage to a 50 gallon tank if a 40 gallon tank has seemed adequate in the past?
Thank you for your time and expertise!
ddmoit
SE Tennessee
It's gas.
Pardon my ignorance, but what is a power vent? I'm assuming that since I don't know, I probably don't have one.
The vent at the top of the water heater is routed through a 4" galvanized pipe into the same chimney flue as my boiler. It looks about the same as any I have seen.
Cwhyu2
Consultant
Cincinnati OH
Power vent uses PVC to for its exsaust through the sidewall.Go with the
recamendations for a normal vent W/H.
heater
If you buy Rheem, Ruud, Richmond, GE, Vanguard, or a couple of other brands you will get the same heater, just different labels. Same with some other brands, i.e., State/AO Smith/ Kenmore/ Reliance, etc. There is almost no difference in heaters. The difference is where you buy them, because some sources seem to get more "defective" heaters than others.
ddmoit
SE Tennessee
OK, I get the picture.
I'm going with the Lochinvar which is what my local plumber supplies and installs. He may even be out today to get it done - pretty decent for a non-emergency.
For a while, I was considering an indirect heat model that I could hook up to my boiler, but I was persuaded otherwise by the prospect of my boiler running all summer.
Thanks for all your informed opinions!:)
ddmoit
SE Tennessee
Update: The Lochinvar was online by lunch time yesterday. There was plenty of hot water for evening showers. Thanks again to all who contribute to this forum!
