View Full Version : no hot water
rbs62
01-10-2008, 05:09 PM
i have a 28 gal w/h 120volt single element water stopped getting hot 1 night and changed the element no hot water changed a second element still no hot water changed the theramt 2 times still no hot water.. i have 117 volt at them and element. it is a side inlet at bottom so no down tube. HELP
Mikey
01-10-2008, 05:39 PM
Unlikely that 2 replacement elements would be bad, but try measuring the element resistance to make sure it isn't open. Turn off power, disconnect one line from the element, measure resistance across both element connectors). Should be around 10-12 ohms, I'm guessing, to dissipate 1200 watts or so.
I assume you're getting good water flow, it's just not hot, right?
rbs62
01-10-2008, 05:55 PM
right, good water flow what do i set my meter on (what resistance level)
BAPlumber
01-10-2008, 11:02 PM
I'm not really up on 120v single element heaters, but I would look for the wiring grounding out on the tank, or some wiring or breaker problem.
maybe you have a leak on the hot side somewhere.
Mikey
01-11-2008, 04:13 AM
Whatever range will show 10-12 ohms and differentiate it from, say, 100 ohms.
Cass
01-11-2008, 04:29 AM
The water heater is grounded so if you are using the tank to check for voltage you may not be getting the right reading. Be sure the neutral is working and then trace the hot side using the neutral and you should find the problem.
BTW you are not turning on the elements B 4 the tank is filled with water are you?
rbs62
01-11-2008, 12:21 PM
it was the bad therm second one put in finlly the thrid therm worked thanks for help.
Mikey
01-11-2008, 02:03 PM
OK. You misled us when you said you had 117V at the element...
