Basboard heater
samlin7
Hi
I am replacing baseboard heater pipe and was wondering should get the 3/4" Copper Type M, L or K?
thanks
Another question, the pipe is running in a crawl space and shoots up into my extension. The crawl space is in too well insulated, is it recommended to insulate the copper pipes? My main question really would be is it ok to insulate hot water pipe (my heat is from hot water)
I meant to write my crawl space is NOT well insulated, so i would like to insulate the pipes in the crawl space
If freezing is a concern you may be best protected by running a glycol solution in your system.
