I'll try to keep it short although its been 3 days of questions. I have a 1/2 hp shallow well pump that is roughtly 12-15 yrs old, same as tank in age. I've suddening started getting alot of air, drained lines and emptied tank, found no air in tank. I put 28lbs in the tank and still seen air spurting at every faucet. Drained out lines / tank the next day and found little to no air in the tank. I assumed bladder was bad because of this and the age of the tank. Installed a new 20 gal tank and have the same problem. Pump is set at 30-50psi and I'm noticing that when its empty and turned on I can see(installed a clear flexible hose )the water without any air until it hits around 45 psi, then I see air until the pump kicks out at 50psi. From 0-45 pounds of pressue I see no air, so it looks just great until it hits around 44-45 pounds? I reduced the pressure to 45 pounds, but now it happens at around 40 lbs. Do I have a pump issue or well issue? No leaks anywhere and some good looking water flow up to a point. I'm thinking about having the well tested or even getting a new pump, but just not understanding why I get air at the top end only? Water pressure looks good to me so can't believe the well is the problem as some of myfriends tend to think.
Thanks,
Dan
Thanks,
Dan
