Siliconed drains come right out as easy as putty. The cleanup of excess caulk is the draw back. One guy I knew said caulk didn't work, he was using tub caulk, not 100% silicone.
I had a problem with the last SS sink drain I put in using putty, I went back to install a disposal and I noticed the drains had been leaking. When I removed the baskets the putty I put in six months earlier was gone. The drain was loose and the gasket on the bottom couldn't work. I never used putty again. The problem, I think was a cheap box store basket that was wavy. The silicone I put in there worked.
The problem may not really be with the putty so much as the cheap foriegn made parts with too much space. The silicone solves the problem so I use it. I used putty for 10 years without issue then all of a sudden several failures. I don't know the reason, but silicone solved the problem.
