Recommendations and help, please...
crosby1
Virginia
Hello all,
i'm just starting a bathroom remodel project. i'll be re-doing the existing shower stall (48" x 48") and would like to have a regular wall shower (we like our speakman showerhead) and in addition, i want to add an overhead rainshower.
1st, the installation. i'm getting confused with the terminology. please correct this if i'm wrong: hot and cold water are run to a thermostatic valve first and then to a diverter valve to get the water to either the wall shower or the overhead rainshower, correct?:confused:
2nd question: can anyone recommend a manufacturer or something that is packaged as a system, or am i going to need to piece a system together?:confused: i'm looking for an oil rubbed bronze finish, and from what i've seen so far, the choices are fairly limited.
help, please??
thanks so much in advance for any help....
It is not exactly sold as one "kit" . You do want to stay with same brand. Moen and Delta are two good brands. If you go with the "designer" brands that you will see at design showrooms, then future parts availability is in question.
Go to a good plummbing supplier. They will have catalogs, and the catalogs show what goes with what, and show you the style and finish choices. You can also see these the K/B desk at HD, but the problem is finding someone who knows anything. The manufacturer's catalogs are pretty good at showing you what trim goes with what valve, and even have diagrams for the mutihead/diverter valve setups. It is not rocekt science if you pay attention. I have seen people order stuff from the depot where A did not work with B.
