jimbadger
- Messages
- 7
- Reaction score
- 0
- Points
- 0
Hi all,
I'm so frustrated... DYI here - installing a whole house water filter as we are on well water and get lots of sediment. I managed to install a water softener myself, so I thought that I could do this!
SO I go through and install a very complicated setup (for me anyway!)
The picture above shows the setup on the right of the filter (the filtered water output). I have put a shutoff valve on each side (as recommended - and for convenience as I don't want to have to use a bucket just to catch all the water when the filter is changed.) the filter has 1" output and input ports and I have 3/4" plumbing, so the first fitting is a male adapter that is also a reducer. That is soldered to a shorter section of pipe which is then soldered to the shutoff valve, and then (because the filter is further out from the wall than the pipe) I use a series of elbows to connect to the rest of the pipe. (the coupling on the right is from a previous mistake!)
When I pressurize the system, I get a small leak at the solder joint between the male fitting and the little section of pipe (labelled 'A') on the photo. Obviously my solder joint sucked. I know that most of you pro's would probably shriek in horror at my solder joints, but I'm not going for style, just so that it holds water! That and I'm new so I'm learning.
I really don't want to have to make a whole new pipe section (as is represented in the photo) as the shutoff valve is very expensive. So I have two questions:
1.) can I undo a solder joint - so say I want to undue joint A - how do I do this?
2.) If I want to then redo the joint, what steps do I need to clean the joint - and when I clean the joint, should it look like brand new copper?
Finally,
When I sweat joints, I apply lots of flux, both to the pipe and the inside of the fitting. Then I heat both the pipe next to the joint and the joint itself - kindof in a back and forth motion. Usually the solder doesn't melt until I start getting steam out of both ends of the pipe. I usually try and run the solder around the whole outside (so I end up with a mess on the pipe, but I figured it would make sure that I had enough). Then, I normally let it air cool, but I do take a moist rag and wipe off any excess flux or brown gunk that ends up on the pipe.
Anything obvious that I'm doing wrong?
Thank you very much for any assistance - I'm getting kinda frustrated as I've spent two days on this!
-Justin
Finally,
-Justin
