View Full Version : Letting pipe dope sit before pressure
edwardh3
01-05-2008, 03:06 PM
The Ace hardware can of "paint on type) pipe dope I have says to let it sit 48 hours before applying pressure.
would this apply to drain fittings also?
48 hours seems long
construct30
01-05-2008, 03:15 PM
I would not use pipe dope that required a setting time. Tephlon paste from oatey or rector seal for gas or water. Check any paste for use with plastics and PVC.
Setting type pipe dope gets hard and cracks, unless you are talking about some kind of solvent cement. Pipe dope is for threaded connections.
What is your application?
If the pipe dope required 48 hours before pressurizing it, you can be sure that no one would buy or use it. Probably a CYA memo from some engineer/lawyer that wanted an "out" if the stuff failed because he could be sure that no one would follow the requirement.
edwardh3
01-06-2008, 11:59 AM
green stuff in small cans- no not pvc cement, but pipe dope.
Is rector seal better (I think this is their generic for rector seal)
Gary Swart
01-06-2008, 12:46 PM
Just get the Oatey that is called Pipe Dope. No fancy schmancey type this or that. But, this stuff is for threaded pipe, not PVC connections like a P trap.
