Cacher_Chick
Test, Don't Guess!
I recently bought a home in S. WI that uses a well system. The house sat empty for a year and when we moved in I flushed the 38 gallon galvanized pressure tank (the type with the air check valve in the side) because we were getting a lot of rust at the tap. The tank flowed dark brown/orange rust for 2o minutes before eventually flowing clean.
I was thinking of replacing the tank and found that it seems that the bladder style tanks are what everyone is using now.
Thus my potential problem- I think we have an "airmaker" pump system. I can hear air bubbling into the tank each time the well pump is energized. I have not been able to find any information online about an airmaker pump system nor any easy and sure way to verify that this is what I am dealing with. Is is a different kind of pump? Does it use a standard pitless valve? I am wondering what my best options will be when I do have to replace the tank or eventually, the pump. Thanks in advance! Russ
