nate
01-04-2008, 06:27 PM
I'm at my wits end on this... maybe you guys can help.
About a month ago I bought the Ultimate Power Shower showerhead off of **** to increase my water pressure in the shower. It did exactly as advertised... and I was loving it.
Fast forward a couple of weeks... my hot water pressure at every outlet in my house slowed to a trickle. The cold water pressure has not changed and is fine. Now I'm dreading my showers because it takes about 10x as long trying to wash myself under this pee stream.
Things I've done to try to fix this:
- Turned off and back on the cold water shutoff valve leading into the water heater, thinking the valve or washer may be causing the slowdown
- Drained the tank by closing the cold-water shut off valve and opening the pressure relief valve to allow the water to allow the water to flow out the drain
- Flushed the tank by opening the cold-water shut off valve back up
- Reverse flushed the tank using the normal pressured cold water fed back into the hot water pipe behind the washing machine
- Replaced the cold-water shut off valve... which was a nightmare story for another post... let me tell you, it was great fun trying to sweat a pipe for the first time 2" away from the framing and insulation in my attic.
Nothing has worked. The heater is gas and was manufacturered in mid-2005 and is located in my attic.
Any ideas on how to fix this?
Thanks
Thanks
