Red triangle on water meter
LiamM
Massachusetts
Hi
I recently noticed that the red triangle on the face of my water meter was moving back and forth by about 3/4 of a revolution. Each time it moved forward-backwards-forward, it ended up a little past where it was.
I didn't have any fixtures, etc turned on while this was happening. Is the only cause of this a leak somewhere? And why would it be moving backwards?
Thanks for any feedback
I would check the water level of the toilet(s). I once had a toilet fill to the top of the over flow and stop then drain down the overflow then fill again. It was a stop go stop go. Then again a bad flapper will do the same thing
Dam, ya got me, I shoulda just generalized and said toilet...good point.
Thanks for the replies, folks.
I'll test the toilets and faucets this weekend, and post an update with any findings.
That is also what happens when a bowl refill tube is too far down the owerflow tube and the tank water level is set too high.
Ya I tend to install the air gap so that doesn't happen. Saves the call backs for something that could have been prevented with one minor piece.
My vote is for pressure fluctuations. I agree that if something was using water, the indicator would only move in one direction.
