adil.hoxha
- Messages
- 8
- Reaction score
- 0
- Points
- 0
Quick history: We built a new home here in southwestern Ontairo (higher up elevation, away from all water sources) last year. Duing the winter months we got a constant flow of water into our sump pit (it went off every 10 minutes or so - I measured it and we were getting about 50+ gallons per hour). I installed a battery back-up as we started the process of finishing the basement. It didn't change through the winter, or the snow melting or early rains in the spring, but later in spring (May/June) it went away; it stopped all summer long (sump pump never went off, even during rainstorms) and my stress was gone too.
Until this winter - once the ground froze up in early December the flow of water came back...same as before. I'd love to know what it is (I'm guessing some sort of groundwater source?) but what I really need it to make sure my basement never floods. We just finished off half of it and I'm not planning on clearning up after a flood...ever...
So, the question is: what is my best preventative medicine?
As I said - I already have a decent 1/3 horse submersible pump in place, working fine (every 10 minutes...) and a simple battery backup pump. But when the original pump goes I've got limited time to get a new one in place (the pit fills up in 20 minutes...)
So here are my thoughts - I welcome input:
1) have the next submersible pump all ready to go - I've seen some with "lifetime" warranties - should I go bigger horsepower? What is the most reliable/long-lasting pump out there?
2) If there is room, I could add another pump (probably the pedastal style) in the pit to double up my protection
3) Or...as I looked into before...add a municipal water powered/no electricity pump - but some plumbers discouraged me from doing this originally (wouldn't guarantee it wouldn't cause a flood - said it was discouraged now(?).
4) Would it be overboard/expensive to cut another pit near the first (I have the room) and set it up with another pump - so if #1 floods the water goes into #2 which is set up with either another submersible pump or the municipal water pump?
I'm open to all ideas...what is the best way to deal with this constant flow of water into the home?
[and sorry about the lengthy post...can you tell I'm stressed about it?]
