gardenfool
retired eductor
Our water heater started putting out LOTS of water through the overflow pipe, so we have been shutting its water supply off when we aren't using hot water. (Pain in the rear!)
Hubby has been purging the pressure through the valve, & that seems to temporarily remedy the problem. (The longer amount of time the water supply stays turned off, the longer the heater will go without building up pressure, after turning the water back on.) It'll start out slow, as "normal" drips, then will suddenly start flowing at a rate of maybe 20 GPM! (We haven't really let it go long enough to measure!)
We bought our home 5 years ago & have had no previous experience with gas water heaters, so we don't know where to start on troubleshooting. I've read on your forum that they should be purged once every year, & cleaned out!
(Haven't done that! I hope we haven't ruined the darned thing!)
The heater appears to be fairly new & we're not having a hot water supply problem... (other than too much of it on the garage floor, when it starts running!) We just don't know why that pressure is building up.
Are we looking at replacing the valve, or the whole heater?
