Steveg91
- Messages
- 30
- Reaction score
- 0
- Points
- 0
Hi folks, my friend's got an Eljer toilet, about a year ago it was leaking; liquid/ odor coming out at floor, I went over and removed it, discovered there was a full inch between top of closet flange and finished floor. I installed four 1/4" flange extenders being very care full to silicone them and screw them down to the subfloor, used wax ring properly, all in all I believe I did a real good job. It seemed fixed, no more leak or odor. Now, it's leaking at the front base of toilet. They don't use a plunger, the pipes aren't plugged up. So I'm thinking the toilet's bad/cracked??? Given the symptoms, does that sound likely??? How can I determine if the toilet is indeed bad????
Thanks so much.....
Steve
Thanks so much.....
Steve
