It basically is a Zoeller pump without the
switch intergrated in the body.....
It works out to about the same price
give or take 15 dollars....
the pump is about 80 bucks the
switch is about 28 dollars...
the nice thing is you can either adjust the level up or
down in the pit
and you dont have to worry about the crappy Zoeler switch
failing next year.
N53 instead of M53 is that setup, pump and switch are separate.
The pricing you gave is similar to what my supply house just quoted.
Only thing is, the guy is hesitant to order. WTH?
He said the boss man would be kind of worried to bring in something that won't move, I told him I'd commit to 5 or 10 right now but I told him he needs to put that on display at the counter.
I believe it will sell in transition from the M53 due to setups that are clearly not in the best interest of that switch holding out.
I just replaced one a couple weeks ago that I feel a copper penny was to blame for it's failure; held the #2 check open and fried the pump. Made boiling water practically in the pit.
I'll send ZP this link to see his opinion on the reliability of this different switch. I would hope that this is way better than a tethered switch; I don't like anything that free floats in a pit that can curl around and lodge against the side of the basin or otherwise.
This new setup to me in my opinion will offer a better setup, longer lasting pump system as in the case......those motors never die, it's always the switch.
If the switch fails, unplug it and replace, pump stays in the pit.
