I need to replace a leaking Square D pressure switch for my submersible well pump. The switch is located on a tee which feeds the tank inlet/outlet. There is no valve to prevent water from the tank form escaping from the port for the switch when I remove the "old" nipple that the switch is located on.
Am I resigned to removing the old switch and letting the tank water spray out while I try to thread the new switch setup into the port, or is there a better way to do this? I've attached a photo of the current setup. I am a rookie, so please excuse any ignorance involved with my question.
Thanks for your help.
