abrogard
- Messages
- 18
- Reaction score
- 2
- Points
- 3
We just moved into a new place and find the shower water adjustment is very, very poor.
It is 'hair trigger' just the tiniest bit more cold water and suddenly it's totally cold. Just the tiniest big less and suddenly it is scalding hot.
Adjusting the hot water doesn't seem to make any difference. I can't open the cold and add hot until I find a good temperature.
So I wonder how we fix this. The 'works' are hidden inside the brick wall. All I can see is the two taps (faucets you call them in the States?) on the inside and outside the house copper piping, looks about half inch, going in, one to each tap, two identical runs of copper pipe.
Inside the house no sign of the 'mixing' mechanism at all. Two taps sticking out of the wall and a flexible metal pipe with the shower head on it sticking out. Everything hidden.
What is likely to be the cause of this, and the fix?
regards,
ab
regards,
ab
