I am a newbie DIY'r, and got myself into a possible pickle. I replaced tile in my 1st floor bathroom, and for reasons I thought was good at the time, decided to remove the closet flange (old tile was under it, and I wanted to ensure new tile was replaced in its place for rigity and thought it would be easiest to get the old flg out of the way entirely. I have a full unfinished basement with easy access underneath, so i cut off the 3" PVC downstream of the 90 elbow, and planned to splice in a new elbow/closet flange. However, now, I here is my pickle...
I have everything cut to size, and I started to trial fit. At least I am that swift. I thought I'd use a (standard I think) 90 elbow with couplings to accept 3" dia inside. Then I thought I'd splice a short 3" dia segment inside my flange to elbow junction. here is the rub. i have an interference of ~ 1/2" overlap between the two pieces. Is is permissable to hack off a bit (~3/8" length)from each side of the joint (ie closet flange extension and 90 elbow each), so the flange is flush w/ the other and I can fit in a 3" segment. Or do they make closet flanges with differnet adaptor lengths? or is there another recommendation. i certainly cannot drop the horizontal pipe to make it fit, or then I'd loose the grade slope for drainage purposes.
ps - I also thought an option might have been to use a 90 elbow, where the side to attach to the flg is a 3" dia segment to fit INSIDE the flg adaptor, but then I only have ~1/2" inside the joint tobond together, and I am worried this is not adequate overlap. thanks.
