mccutch2
03-24-2005, 03:13 AM
The Kohler K-9132 literature mentions sliding the drain pipe at least 1.25" into the bottom of the 9132 assembly - then, as I will do, slipping the internal gasket (coated with soapy solution) over the pipe. In this case, I'll be using ABS pipe.
Is this then sealed with clear silicone from above (looking down into the assembly/gasket/pipe), or is there another method? I have not installed one of these before and am looking for a seal that will not leak (obviously!)
Placing this into a K-1668 shower unit. I understand that the gap between must be sealed w/ silicone. Thank you for any advice!
