Howdie all,
I've recently moved my furnace from one side the house to the other. By doing so I needed to remove the double laundry tub in the basement.
But as you can see from the image 3" copper stack with a 1" vent and I beleive the drain starts as 1 1/2" with a reducer to a 2" drain.
Problem is... I can't move the wash machine cause the new furnace is just to the right of the drain and I require at least 24" from the front of the furnace door.
What would be the best way to drain the washer? I know I'd need at least 2" drain for a standpipe.
