The Plumber From Hell
I thought I would move this thread title up to the plumbing section.
Things people still want to know about the existing job on Jon4's mobile home are:
1) Has the water leak been found?
2) Has the water temperature issue been solved?
3) Should a plumber supply his own parts, or should the homeowner supply them?
4) What worries are there if polybutene piping is found?
5) Where are pipes normally run on a trailer home?
OK, Terry, I don't know where you moved it from or what it was about, but here are some general answers to the questions:
Some of them.
No.
If the plumber is flat rate, it doesn't matter.
PB pipe in a trailer usually means a repipe to be safe. Acetal fittings tend to crack whenever they like; aluminum, dog-ear crimp rings crack whenever they like; if the water has antibacterial chemicals in it, the pipe will disintegrate.
In the most difficult place possible. To find leaks on a trailer house, start by laying in mud. That's a sign that you're close. Then cut out the fabric above you and have plenty of towels handy. Then remove the sopping-wet fiberglas insulation. Call home, tell the wife to meet you at the door with more towels. Bring in a small trenching shovel such as an Ames army shovel and dig a hole deep enough so that you can work a set of crimpers. Call the paramedics before the next step: wrap the pipe with heat tape and insulation and plug it in.
