View Full Version : tankless recirculation
jjfta
12-11-2007, 07:51 PM
I was hoping to get a few expert opinions on how to provide a hot water recirculation system to my new tankless installation. There seems to be few different ways to provide instant hot at all fixtures. I have considered them all but since I have an existing 1/2" recirculation line I think it might be my best option. The attached schematic shows what I'm working with.
palmstate
12-11-2007, 08:06 PM
Why did you decide to go takless then add a recirc pump?
master plumber mark
12-11-2007, 08:18 PM
I dont know how a tankless would work with a recircualtion
line.....
woudent the flow of water through that system automatically get that burner going ?????
in theory wouldent it be going all the time as long as their was some flow inthe pipes.....
I would also consider the extra wear and tear on
the tankless unit
i know that the normal tank type gets over worked in a
recirualtion system and burn out early...
jadnashua
12-11-2007, 08:45 PM
Most tankless systems I looked at (that was only a few) strictly prohibit use with a recirculation system. Carefully read the specs on the one you have.
All of the savings you thought you might have by putting one in will go up the flue if it has to run continuously. If you really want instant hot water, you probably want to do something else...
master plumber mark
12-11-2007, 09:26 PM
I hope that their is a way to do this but
I think its just another reason not to buy one
Dunbar Plumbing
12-11-2007, 09:48 PM
I might of landed a job putting in a HUGE Rinnai tankless.
Guy just bought the house, has 8 people living in the house. 5 kids and 3 adults.
No chance for any water heater supplying that demand.
Told him to go with an oversized tankless for his needs and only because he wants tankless.
But when I told him that it'll cost as much as the heater to install it, he pulled back.
And when I told him that the sections of stainless steel piping near $100 a 4 foot section, he sat down.
Then I told him that he needs to clean the compartment regularly for hard water, he took medicine.
When I finally told him that no one in the area works on them and that hot water would take days, not hours to accomplish, he passed out and fell out of the chair. :eek:
In all seriousness though I told him that he would be one of the better candidates for the application figuring the requirements of so many back to back showers. Two water heaters I don't believe would work given the confined space the area allows.
I'd kill to have his tax status though; government probably pays him to have created all those social security numbers!!!
Bob NH
12-11-2007, 10:29 PM
If you put a 2.5 or 4 gallon point-of-use heater at the end of the line where you were planning to put the recirculation point then the system will provide the hot water you need and will work with your tankless heater. They run on a 120 Volt circuit and don't waste as much energy as a recirculation system. Check out Ariston.
The only problem with them is that they are so simple, reliable, and inexpensive that nobody promotes them very much. Not enough whizz-bang or high tech.
FloridaOrange
12-12-2007, 06:52 AM
I've desigend a system with a tankless and a 6 gal for recirc purposes. AFAIK it worked rather well.
jadnashua
12-12-2007, 09:16 AM
Which brand and model allows recirculation? Those I looked at specifically prohibited it. It's been awhile, I haven't looked recently.
One of the big advantages of a tankless is you can put it closer to the point of use since they are all pretty much closed systems and need minimal clearance. Then, you won't have huge lengths of lines to heat. If things aren't centralized, you may be best served with several, though or you'll run into the same problem.
WHen I experienced them in Germany, it was located in a closet right next to the bath. It took a little longer for heat to get to the kitchen, but that wasn't as big a deal.
AZ Contractor
12-12-2007, 10:09 AM
The Rinnai's allow circulating pumps.
Lancaster
12-12-2007, 03:25 PM
Rinnai does indeed allow for a recirculation line but only if you do it the way they show you in the installation manual,which is with the small point of use tank.Any other method reduces the warranty on the Tankless by one half.They teach this in their installer certification class.Ive heard it said lately the certification is no longer needed to purchase their units,dont know if its true.
Marlin336
12-12-2007, 05:59 PM
You're probably basically using a tank less to fill a tank, correct? I don't see why that wouldn't work without putting undue stress on the tank less.
FloridaOrange
12-12-2007, 07:34 PM
Basically yes. I'd have to dig through some archives to find the exact routing/valving that we used but yes, the tankless filled the tank. The recirc was back to the tank, not the tankless.
Bob NH
12-12-2007, 09:17 PM
Unless the "tank" is a water heater then the recirculation will eventually cool off the tank and the result will be only to delay the cooling. Furthermore, that 6-gallon tank will become a "tepid tank" after a while and that 6 gallons will have to go down the drain before really hot water arrives at the faucet.
A heat and mass calculation would show that addition of a recirculation system AND a 6-gallon tank that will eventually be filled with tepid water will not be an improvement over putting a smaller point-of-use heater at the point where the hot water would be recirculated. It could me made to work in that it would deliver hotter water sooner for cases where there is limited time between water usages, but even in that case it will waste more energy.
Simpler is almost always a better design, and one small point-of-use heater is simpler than a tank + recirculation system. The only justification for the recirculation system would be if analysis showed that it actually improved on the simpler system, and that can't be shown by thermal loss or any other analysis.
I've installed recirc systems with tankless. You definately do not want to utilize the tankless as part of the recirc system or, you cut the 10 year warranty in half. But if you use a little Ariston, (say eight gallon) with a pump and expansion tank you will have little problem. The small electric w/h supplies the recirc, then once the call for hot water is triggered the Rinnai flows through the Ariston, ensuring it is kept hot.
I have one where the Rinnai is approx. 100' or so from the master bath. The cust has never complained about waiting for hot water. This was installed about 2 years ago
jadnashua
12-13-2007, 07:56 AM
So, basically, with a tankless, you need another WH, albeit small, to supply the recirculation loop. that makes sense, as keeping the tankless on the whole time the recirculator is running would add signficantly to the typical duty cycle. So, you can't or at least shouldn't JUST add a recirculator - there's more to the story.
Thanks, you've confirmed my thoughts.
Bob NH
12-13-2007, 01:24 PM
If you put the 8 gallon Ariston AT THE MASTER BATH then you don't need the recirculation system. The small amount of water in the supply pipe mixes with the 8 gallons in the Point-of-Use heater to keep the temperature up where it is delivered and the tankless heater will supply the makeup.
Avoiding the recirculation will avoid the constant loss of heat due to recirculation of hot water from the heater. Because the objective is to keep the water in the supply pipe hot there will be heat loss from two pipes that must be made up by electric heating.
The recirculation pump and pipe are unnecessary.
Keep it simple. Skip the recirculation!
jadnashua
12-13-2007, 04:43 PM
If there were multiple bathrooms you wanted to keep near instant hot water to, you'd still want the recirc, but I think the complexity and energy costs may make it kind of expensive. Then, I suppose if you've got a house big enough to need it for multiple bathrooms you may be able to afford it, too (at least for now!).
jjfta
12-13-2007, 09:04 PM
Tons of good discussion here.
So the option of an on demand type recirc system (Taco or Ready Temp) that push the hot back up the cold line is not a good option for the Rinnai system. I did not like the idea of having luke warm water in the cold line anyway. Certainly do not want to lesson my warrantee.
Using a point of use tank with out a recirc, I do not think will work for me as the tankless is located 35 feet from the master bath, and 60 feet from the Kitchen. I would most likely need two instant hot tanks (still may be more economical though).
It sounds like my best option would be to install a small electric tank in accordance with the Rinnai schematic shown in their installation manual. In my case I all ready have the old existing recirculation line. I will just need to extend it 30 feet.
If I go that route, what size electric tank do I install (Rinnai recommends 2 -5 gallons)?
What size recirculation pump? (I plan on using the UP10 series from Grundfos). This is a small pump with temp sensing controls; I hope it is enough hp.
In addition, what size expansion tank should I use? I have know idea why an expansion tank is recommended from Rinnai
Thanks again to everyone for all of the good discussion.
On the size of the water heater you need to make sure that it has 3/4 inch inlet AND outlet, because the main hot line sytem also runs through this. I have found the Ariston 8 gallon model to fit the bill.
A normal Grundfos recirc pump to be sufficient. The timer model is nice in that it doesn't have to run at times when there is no need.
The expansion tank is around 2 gallons and just a normal water heater safety tank. It's main purpose is for the "closed" system of the recirc line.
3390 Here is one installation. It is installed as per Rinnai specs.
jjfta
12-14-2007, 12:32 PM
GMT, thanks. The picture helps a bunch. Please see the attached. I want to make sure I completely understand the plumbing. I have labeled the pipes. Let me know if my assumptions are correct.
Boy that picture is big!
That's pretty much it. Just go by the diagram (Noritz/ Rinnai) whatever and install the check valve where it says.
My advise is to stick to one of the big three manufacturers...Rinnai, Noritz or Takagi. I believe all three have somewhat similar systems
Good luck!
rdtompki
12-14-2007, 10:43 PM
If you go to the Noritz website you can pull down a pdf installation manual for one of their WH, the 69M for example. They have a diagram of an approved recirc system. I put in the tankless at the far end of the house as part of a remodel. Didnt choose to recirculate, but I have considered a Chilipepper recirc. pump or similar. Could use an X-10 outlet to control from some other point in the house. For the time being I just run the water as long as necessary; only the kitchen and laundry room are affected so this is not too critical.
If the hot water demand is large you might consider two mid-sized units like the 69M. These can be mounted in parallel and will self-control via a cable interface. I've been very happy with the unit so far (1 year). Love the constant temperature water.
Rick
drewcwsj
02-10-2008, 09:18 AM
I just purchased a new construction home in Austin, Texas with a Rinnai tankless system. It has two Rinnai units mounted in the garage. There is no recirculation line. The home is 3500 square feet.
The problem is that the master bath is connected to the Rinnais with about 70' of 3/4" copper. It takes over 4 minutes to get hot water. Is there anything that can be done? I'll be meeting with the builder next week.
