Chinese Faucet Water Supply Lines
airstreamingypsy
In an Airstream Trailer
Hi All,
I'm remodeling a bathroom for a friend. She bought a great looking faucet,
The Taron 101. Notice it says, it comes with all connection hoses. Well, my friend bought fancy water connections and satin nickel supply tubes because under the sink is all exposed.
Here's the problem, no one has ever seen anything like the hot and cold supply line connetions that are up in the faucet. I went to Fergusons today, hoping to find an adaptor but no joy.
If anyone can help I would really appreciate it. I guess I want to know if anyone has ever adapted a Chinese faucet to regular standards.
I put a picture of the connection on the web...
http://members.aol.com/airstreamin/watersupply.JPG
Help!! Please.
Hunter
faucet
It is not just a Chinese faucet problem. Many manufacturers have a proprietary connection into the faucet, and NONE of them can be retrofitted with any other type of connection.
Thank you for the reply. Not good news. Seems like someone could make a fortune making adapters for these faucets.
I guess I'll find a different faucet. How do I know which ones will accept the bullnose supply tubes?
Hunter
faucet
They all will once you arrive at the REAL connection point which is where the manufacturer intended that you connect your supply lines to the faucet. You are trying to take a shortcut and connect directly to the faucet when the manufacturer intended that you connect to the ends of the flexible lines he provided to make your installation easier.
I see your friend shops for plumbing fixtures at the same places my wife does. :) I've found that just about any fixture for which the ad copy says "comes with all connection hoses" will be like the one you have. In the interest of marital harmony, I look at the photo of the really nice looking fixture she has found (be it plumbing, electrical, etc.) for a really fabulous price and try to find something similar in style, that I can get parts for, for around the same price. For plumbing fixtures, that usually turns out to be something made by Price Pfister. You will also find that chrome costs a heck of a lot less than satin nickle. I think you will find that most, if not all, Price Pfister lavatory fixtures accept what you refer to as bullnose supply lines.
-sam
Have you scanned the directions?
If it is a widespread faucet, they will have hoses that go from the handles to the spout/body. That's what your picture looks like. Often you will have more than one set of hoses. these days.
They all will once you arrive at the REAL connection point which is where the manufacturer intended that you connect your supply lines to the faucet. >
Yeah, I know, because the satin nickel tubes look so much nicer than the flexible lines.
The good news is, my brain kicked in and I realized I can loop the flexible lines up under the counter and attach the tubes to them and only the tubes will show.
Thanks all.
Hunter
that Chinese Faucet
if it is from China , most likely it will begin leaking
when the substandard metals begin to corrode in it
anytime in the next few months....
When that happens, good luck getting parts...
they cant even build a Delta Faucet to specs
that wont leak from the get go---
so take some pics of the internals of the unit
and post them when it breaks down
