Have you ever seen this
Had a call about a leak on the my NEWLY remodled unit. I went there and it look like the tp valve let out water like it was suppose to and tenants had the temperture way tooo high!! I turned it down and said call if any other issues. Did not see any leak going on while i was there.
Well 2 days later this time its alot worse, carpet satuarated with water. I check the water heater again, just see water , no leak,hmm maybe the bottom is leaking. Look at the bottom its rusted pretty good so its POSSIBLE but still didnt see a leak happen while im there. I even check the pipes and everything. I buy new heater just to be sure (everything else is new anyway). Well while i install the water heater, I test it and turn on faucets/main water too. still no leaks.
Turn off faucet and start cleaning, then WAALLA!! a leak starts. I see from The ceiling theres water going. I go upstairs, no leaks,or anything on!!I scratch my head , go back down and start tracing that leak.
Well i found it, I could KICK myself. the old copper flex to the water heater had a pin hole 'pressure' leak. the spray too light to almost see.
I call it a PRESSURE leak because it ONLY leak when there was enuff pressure. See when the tenant would use the shower/sink hot water, it would NOT leak. So when the faucet is off the water tank heats and builds pressueR and then at night when everyone is sleeping, it leaks and when they get up and use the bathroom it STOPS!!
Ever see anything like this?? How would one ordinary find this type of leak??Im still amazed at how some plumbing works
