View Full Version : Price Pfister shower trim?
Guest
12-10-2007, 01:09 PM
Will standard Price Pfister shower trim work with this?
chassis
12-10-2007, 07:21 PM
Doesn't look like a Price Pfister valve you have there. My bet is it won't work. Buy something that HD/Lowe's has in stock, and try it. If it doesn't fit, they should let you return it. Check their return policy before you try this.
12-10-2007, 08:20 PM
That is a Price Pfister unit so you can use any PP trim you can find, as long as it is not the Verve line which has a different flange and method of securing it. If you buy a complete new PP faucet, remove the seats from your valve and throw them away, then install everything from the new one into your valve body, but DO NOT install any seats once you remove the old ones.
chassis
12-10-2007, 08:36 PM
Oops I stand corrected. Thanks hj.
12-11-2007, 12:08 AM
Thanks hj, I will forward on the advice.
He's hoping to go with Satin Nickel if it's available.
12-11-2007, 06:17 AM
Satin Nickel is very common these days, although somewhat expensive.
