ski
First off I do not pretend to be a plumber. I am currently building a house (slab on grade) the plumber I used installed the toilet flanges. The one downstairs on the concrete slabe which is the finished floor is about 1/2 inch above the floor and not anchored to the floor in anyway just glued to the riser. Any idea on best method to reset the flange properly? The plumber has decided he doesnt want to come out and fix any mistakes. Also upstairs flange is also high but flooring would probably make it the right hight but it is also already glued in. Would it be better to cut it off, lay the floor, then glue it back in and set it flush to the floor? I am assuming by what I have read that the flanges should be sitting flush on the finished floor that way when the toilet is set it rest on the floor not just the flange assuming things are leval. Thanks for any info and help.
