View Full Version : How far can a main vent pipe run horizontally
snuffysmith1978
03-22-2005, 08:46 PM
I have put in a downstairs bathroom. It is a remodel job in my house. I haven't done much of this kind of work. I have a problem trying to get the main vent up and out. If I could run it horizontally for 20 feet then up I could make it work. Any ideas?
03-22-2005, 09:09 PM
The way you ask the question it would be okay, but there could be other factors you are not telling us that would preclude installing it that way.
snuffysmith1978
03-22-2005, 09:29 PM
What do you need to know? This is a bathroom I made by dugging out a crawl space. Its in a corner of the basement I have the vent pipe up through the bathroom floor but because the house is finished upstair I am trying to find a wall that I can make enough room to get the main vent pipe through its a 4" pipe. Iam finishing a small addition that I could go up through but its 20' from the pipe I have up. :rolleyes:
03-23-2005, 06:18 AM
As long as you are not using an existing drain pipe for the vent it can offset wherever necessary, but in your installation a 2" vent may be all you need.
03-23-2005, 10:34 AM
A vent can be 1/3 the distance horizontal to 2/3 vertical.
If you have more horizontal than this, you can go up one pipe size.
Most bathroom sets that include a toilet only require a 2" pipe, so if the horizontal is too far, then the next size up would be 3".
You may check with the inspector though, he may consider the 20' okay.
UPC code 904.2
http://www.iapmo.org/common/ROP2004/upc04rop/preprint/ch9.pdf
snuffysmith1978
03-23-2005, 06:28 PM
Thanks for the help :) This is really a great site. The best i have seen. You have some great answers for alot of problems. Thanks again.
