1. Do PRV's installed on the outside of homes typically go bad w/in 10 yrs?
2. Is it code to install a pressure relief valve after the PRV on the outside of homes in Southern California?
3. @ what pressure does a factory installed TP valve open on a water heater?
4. @ what pressure would a PR valve on the ouside of the home be set?
5. If the PRV went bad and I had 150 lbs of pressure go into my home, wouldn't the TP valve on the water heater open before damage in my home?
