View Full Version : pex crimp tools
tedn332
12-03-2007, 07:56 PM
I have the Zurn pex crimp tools (1/2 and 3/4) . Confused with the compatability charts - will these tools work with the Vanguard crimp rings and fittings? Thankyou, Ted
construct30
12-03-2007, 08:22 PM
The chart says the zurn crimp ring tool will work on the crimp rings and the stainless steel cinch rings. They are compatible in the perfect world. Use the correct go no go gauge and the vanguard rings pipe and fittings, I wouldn't mix and match fittings, pipe and rings just yet, people do, but who knows for sure.
I have limited experience with PEX, I use it for repairs. I like working with it. Given that most failures are due to the fittings and not the pipe, I would use a home run system with a manifold and not hide fittings in the wall.
As many have pointed out, copper pipe does fail. It seems that it is not lasting as it should. The PEX tubing is great stuff, I think the fittings and crimps are the weak point so far.
http://www.pexinfo.com and http://www.plasticpipe.org/pdf/pex_pipes_for_plumbing.pdf have a lot of good info.
construct30
12-03-2007, 08:45 PM
According to the plastic pipe institute article, the linear expansion is 1 inch per 10 degree F per 100 feet. example: Hot water pipe 50ft long, 50 degree F. rise will lengthen pipe by 2.5 inches. That is why PEX should be strapped to allow for movement. People strap PEX tight to make it look like copper and then they wonder why fitting break and leak.
