View Full Version : Leaky Brushed Nickel Nipples
scottg
12-03-2007, 10:39 AM
I’m finishing a bathroom remodel and am, having a problem installing the supply nipples for the water closet and lav. I have drop elbows in the wall and am using 1/2” brushed nickel nipples with 1/2” brushed nickel threaded angle stops. I’m having difficulty getting tight joints. I’ve redone the water closet supply three times and it still leaks. The joints are being made with teflon tape. I’ve tries to vary the amount of tape, from minimal to the amount used for regular brass fittings to double the usual amount. They all leak. When I doubled the usual amount, the leak was minimal, a few drips per hour. I’ve done a fair amount of regular brass joints and they are tight.
Are there any tricks to getting these things tight? Any other material besides Teflon tape that would give better results? I’m assuming that the smooth surface of the brushed nickel is at least contributing to the problem.
Thank you in advance,
Scott
cwhyu2
12-03-2007, 11:23 AM
Use a thin coat pipe dope then thin teflon tape then thin coat pipe dope.
This sould help.
