I have no pressure
Mad Plumber
Mad Skills
i have no pressure and when i turn on the water a gurgling sound came out and now there is nothing happening no sound and no water is coming out.I have checked the pump and it runs constantly with out water coming and i have primed the pump but nothing has happened. I do not know how old the sand point is since i have only lived there for four years. Any advice with this will be thankfull. sincerely Ms. Milligan
I hope you turned the pump off before it melted the impeller etc.
If you had primed the pump, it should be pumping water unless there is an air leak or the above already happened.
bob...
