View Full Version : Adding a zone to my Hot water heat system
rockycmt
11-13-2007, 06:45 PM
I curently have a 3 zone system. 1 zone is for an indirect hot water heater and the other 2 are heating zones. I would like to create 2 more zones. The zone valves are honeywells. They are 24volt vales and my system has 1, 24 vold transformer. I was wondering home many valvas I can run off that transformer? Is there a limit? I want to avoid adding to the exixting loops as to not create a long run.
Thanks,
Chris
jadnashua
11-13-2007, 08:29 PM
the spec sheet for the valves will have a VA or wattage. Add them up, and compare with the available current for the transformer...you might be okay, but you may need a bigger one.
Steven62
11-14-2007, 06:48 AM
If you still need help with this, give the guys at Watts Radiant a call. Ask for Hydronic technical help. 800-276-2419
They will help you design the best option!
rockycmt
11-15-2007, 08:15 AM
Thanks for that contact. I will try it.
Also,
Out of my boiler I have threaded iron pipe(I guess). Can I convert it to 1 inch copper to add 2 zones. I am very familiar with sweating copper and rather do that then rent a threader to build off the current manifold.
